Updated spanish translation
If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
somnoliento
Post by somnoliento » Sat Jun 14, 2008 8:43 pm
I just updated and completed the spanish translation, based on zm_lang_es_ar. I've uploaded it to zm_lang_es_co.php - it is a UTF-8 text file.
To whom should I send it so that it gets included in ZoneMinder?
cordel
Post by cordel » Sat Jun 14, 2008 8:54 pm
Thank you for this.
As long as it's available here at the time around the next release, this should be sufficient 8)
somnoliento
Revision 1.26
Post by somnoliento » Thu Jun 26, 2008 4:09 am
I just uploaded revision 1.26 to the Latinamerican Spanish translation file.
Changes:
  • Made a difference between video file and streamed video
    New section in the comments to ease spanish translations in other regions
The UTF-8-encoded file can be found at http://somnoliento.com/files/zm_lang_es_co.php.txt
patofasolino
Re: Updated spanish translation
Post by patofasolino » Wed Mar 27, 2013 12:15 pm
Hi guys, I'm Argentinian and I'm using zoneminder (great software!!) and I want to do my small contribution.
You want me to translate those lines in English in the es_ar.php file?
I found some lines not translated there as
'AddNewControl' => 'Add New Control',
Please, If can I help in some way, let me know.
Thanks for all.
