Hi all
I have one card dvr model:
CP-1400AS (look: http://www.monitormaster.com/dvrboard.htm)
but, only channel is visible (channel #3)
my dmesg:
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:04:04.0[A] -> GSI 18 (level, low) -> IRQ 177
bttv0: Bt878 (rev 17) at 0000:04:04.0, irq: 177, latency: 32, mmio: 0x90001000
bttv0: subsystem: 8281:55aa (UNKNOWN)
please mail id, board name and the correct card= insmod option to video4linux-list@redhat.com
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00fffc0a [init]
bttv0: using tuner=4
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
Somebody successfully uses this card in zoneminder?
what is the best config for modprobe.conf ?
Thanks all
I-View CP-1400AS
We also have this card for a system at a store I'm work for and I was looking to run linux on it instead of Windows for stability (and the computer's currently running Win98 :/). I'll be working on it within a couple of days so I might be able to add some input. The reason I posted though is because I found some information on the card that might be useful. Not a tutorial to get it to work but information for someone who knows what they're doing.
Source: http://cassy.dfmk.hu/~cassy/drivers/TV/ ... allery.de/
Iview I-View www.ezwatchstore.com
"EZ Watch Pro" digital surveillence system
chips. bt878 (with head sink), xtal 28.6z8, xtal4, U3 24c02, U11 74hc00d, U10 mdt10c61p, u13 74hc4051, u14 lm71 71, u15 lm1881
connectors; 4x BNC, audio in (yellow)
connector backside: J9 (PC Reset), red LED
pcb: i-view CP-1400AS v1.4
0000:00:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device 8281:55aa
0000:00:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
bttv0: Bt878 (rev 17) at 0000:00:08.0, irq: 10, latency: 64, mmio: 0xdfcfe000
bttv0: gpio: en=00000000, out=00000000 in=00ffff0a [init]
from INF:
[Microsoft]
%BT878.VDeviceDesc% =BT878.Device, PCI\VEN_109E&DEV_036E&SUBSYS_55AA8281
%BT878.VDeviceDesc2%=BT878.Device2,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8292
%BT878.VDeviceDesc3%=BT878.Device3,PCI\VEN_109E&DEV_036E&SUBSYS_55AA82A3
%BT878.VDeviceDesc4%=BT878.Device4,PCI\VEN_109E&DEV_036E&SUBSYS_55AA82B4
%BT878.VDeviceDesc% =BT878.Device, PCI\VEN_109E&DEV_036E&SUBSYS_55AA821C
%BT878.VDeviceDesc2%=BT878.Device2,PCI\VEN_109E&DEV_036E&SUBSYS_55AA821D
%BT878.VDeviceDesc3%=BT878.Device3,PCI\VEN_109E&DEV_036E&SUBSYS_55AA821E
%BT878.VDeviceDesc4%=BT878.Device4,PCI\VEN_109E&DEV_036E&SUBSYS_55AA821F
%BT878.VDeviceDesc% =BT878.Device, PCI\VEN_109E&DEV_036E&SUBSYS_55AA8210
%BT878.VDeviceDesc2%=BT878.Device2,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8211
%BT878.VDeviceDesc3%=BT878.Device3,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8212
%BT878.VDeviceDesc4%=BT878.Device4,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8213
%BT878.VDeviceDesc5%=BT878.Device5,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8214
%BT878.VDeviceDesc6%=BT878.Device6,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8215
%BT878.VDeviceDesc7%=BT878.Device7,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8216
%BT878.VDeviceDesc8%=BT878.Device8,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8217
%BT878.VDeviceDesc% =BT878.Device, PCI\VEN_109E&DEV_036E&SUBSYS_55AA8250
%BT878.VDeviceDesc2%=BT878.Device2,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8251
%BT878.VDeviceDesc3%=BT878.Device3,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8252
%BT878.VDeviceDesc4%=BT878.Device4,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8253
%BT878.VDeviceDesc5%=BT878.Device5,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8254
%BT878.VDeviceDesc6%=BT878.Device6,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8255
%BT878.VDeviceDesc7%=BT878.Device7,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8256
%BT878.VDeviceDesc8%=BT878.Device8,PCI\VEN_109E&DEV_036E&SUBSYS_55AA8257
Msft= "I-View Communication Inc."
MsftMfg= "I-View Communication Inc."
BT878.VDeviceDesc= "WitnessXP PCI0 Device Video Server Capture"
BT878.VDeviceDesc2= "WitnessXP PCI1 Device Video Server Capture"
BT878.VDeviceDesc3= "WitnessXP PCI2 Device Video Server Capture"
BT878.VDeviceDesc4= "WitnessXP PCI3 Device Video Server Capture"
BT878.VDeviceDesc5= "WitnessXP PCI4 Device Video Server Capture"
BT878.VDeviceDesc6= "WitnessXP PCI5 Device Video Server Capture"
BT878.VDeviceDesc7= "WitnessXP PCI6 Device Video Server Capture"
BT878.VDeviceDesc8= "WitnessXP PCI7 Device Video Server Capture"
