Hardware sufficient for 7 Cameras?
Godot
Post by Godot » Fri Jul 10, 2020 7:33 am
Hello
I am relatively new to Zoneminder and between beginner and semi in Linux.
I currently have 7 cameras (4x Reolink 410 with 2560x1920 and 3x Sricam with 1280x720) running on an old Dell Studio XPS 8100 (i5@3.2Mhz with 16GB Ram) on a Debian system with Docker (dlandon-Image), currently without hooks, event notification, etc.
Before I go deeper into the matter: is it basically possible with this hardware combination to save all camera streams at the same time, receive notifications with facial/plate recognition and also work smoothly to check the Events?
burger
Re: Hardware sufficient for 7 Cameras?
Post by burger » Fri Jul 17, 2020 2:22 am
Going to depend upon FPS / analysis settings.
You can try to add things, and scale back FPS / resolution as needed.
These systems are quite flexible.
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
If you are new to cctv, read this:
Users browsing this forum: No registered users and 6 guests
