Requirements
jelseinew
Requirements
Post by jelseinew » Fri Mar 27, 2020 1:30 pm
New to Zone Minder...
Setting up a system with 4 IP POE Cameras with these Video Specs
Compression:H.265;H.264;H.264H;H.264B;MJPEG Frame Rate;Main Stream
3M(1~20fps)/1080P/720P(1 ~ 25/30fps)
Sub Stream;D1/CIF(1 ~ 25/30fps)
Bit Rate:H.265: 32K ~ 4156Kbps
What kind of hardware requirements (CPU / RAM / etc) would be suggested to run this?
Would this work - Core i5 (I5-3210M) /16 GB RAM?
If more information is needed, please let me know and i Can provide it!
snake
Re: Requirements
Post by snake » Fri Mar 27, 2020 2:42 pm
4 720p or 1080p cameras with an i5-3210M (two cores) will probably be ok. Though, keep in mind that you will have to limit the framerate (on the cameras webpage). 5 FPS for 4 cameras should be doable, but 30FPS for 4 cameras... You would need to test. You are essentially watching a number of video streams at once, with some added math on top depending on what setting you use (mocord, modect, record).
You should use H264 passthrough when possible.
Users browsing this forum: No registered users and 7 guests
