I have several Wansview cameras and they are running great in ZM, but I just bought a 2 camera deal that is the new W4 "cloud" camera... I cannot set a static IP, there is not a username password for each, in fact I had to download the separate Wansview Cloud App, to get them up and running..
Anyway I have tried every RTSP combo, tried doing an Onvif probe, etc.. but cannot seem to get a picture up on my Montage.
Anyone else successful with one of these cams or have any idea what I need to input
Wansview w4 cloud cam
Re: Wansview w4 cloud cam
Hi
I see this post goes back to March, 2020, but, I've just bought 2 of these IPCams on Prime day, and, I was planning to use ZoneMinder as my Linux based software. Since there was no replies, either from a forum member or the OP, I'm assuming there is a problem with these Cams. If that's the case, can someone confirm? I was willing to experiment with ZoneMinder to get them working, but, if the consensus is that they're too problematic, then please let me know, before I unbox them.
I was in too much of a hurry buying them, usually I do much more investigating before I make a purchase, but, it was Prime day, and I only had a limited time before the deal was over. Amazon makes returns easy, so, I'd rather return them and look at your compatibility list, and, find a better candidate.
Thanks in Advance
Tom
Thanks in Advance
Tom
from https://www.ispyconnect.com/man.aspx?n=Wansview
the link seems to be rtsp://IPadress/live/ch0 & rtsp://IPadress/live/ch1
try doing a test with vlc 1st
Anyone ever get a wansview w4 to work with Zoneminder? The suggested rtsp line did not work, sigh.
Users browsing this forum: No registered users and 7 guests
