Hi all!
Does someone have experence with this cam?
https://www.aliexpress.com/item/33038356757.html
Do you think it's expected to work with zoneminder? In particular:
- Zoom
- PTZ
Or in case suggestions about somehing similar expected to work?
Or suggestions to NOT choose this model and why?
Thanks!
Simon
Supported? BESDER 4X Auto Zoom IP Camera PTZ Outdoor Waterproof SONY IMX323
Re: Supported? BESDER 4X Auto Zoom IP Camera PTZ Outdoor Waterproof SONY IMX323
Hello!
Is there a guide to follow?
I'm pretty sure all is supported until via OnVif client it works.
Thanks!
Simon
Thanks!
Simon
Applying ONVIF profile I'm getting this error trying to move it:
Ideas why?
==> zmcontrol_9.log <==
04/20/2020 10:09:51.336707 zmcontrol_9[14344].FAT [ZoneMinder::Control:67] [decoder_control.cgi?command=0 not object from ZoneMinder::Control::onvif:68]
==> zmdc.log <==
04/20/2020 10:09:51.431486 zmdc[13974].ERR [ZMServer:705] ['zmcontrol.pl --id=9' exited abnormally, exit status 255]
I've found the issue, maybe needs to be corrected on ZM side.
The NetCat.pm file doesn't get the 'ControDevice' setings.
After forcing it in the code to '000', it works, even the code seems correct.
Bye, Simon
Bye, Simon
