"Capturing" but not seeing any video
thesun
Post by thesun » Sun Nov 10, 2019 5:47 pm
I am a total newbie to ZM and video cameras in general, so apologies in advance if these are basic questions. After trial and error, I've managed to set up a camera that I have NO IDEA if it's even supported (An Eversecu Solar-powered Wireless cam) in a 1.32 install of ZM. I basically just played around with settings for about 3 days and have noticed that I can get a "Capturing" notice in the Console, which seems like it's good. But I don't know if this camera works at all with ZM (or anything except its rather finicky app) as regardless, I don't get any video. So I'm curious whether I've just "deceived" ZM in some way...or if it's rather an "You're almost there" situation...I need to adjust X or Y or Z and it should work.
Does anyone know? Is there a way to offer you guys more information that's necessary?
Also, is there a way to easily dump my settings to a text file so I can share them here? Or should I post screenshots?
Thank you for any help!
snake
Re: "Capturing" but not seeing any video
Post by snake » Mon Nov 11, 2019 5:20 am
Try to get the camera to work in either ffmpeg or VLC first.
See http://wiki.zoneminder.com/Finding_Camera_Stream_Paths
You can post pictures or text. Pictures are best for the settings.
For the logs, you can just copy and paste the text.
If you are new to ZM, It's good to test a known camera first, so you can make sure everything is working. Buy an old used axis or hikvision. They are easy to configure. It's encouraging to make some progress, right off the bat.
Users browsing this forum: No registered users and 19 guests
