Kodicom card on ubuntu 16.04 or latest
bergenst
Post by bergenst »
Anyone know how to fix the kodicom card problem on newer versions of ubuntu16/18lts?, when you type dmesg it appears the kodicom card as "unknown generic" to fix on older version that you have to put some lines in the /etc/modprobe.conf file, then it will be fixed on my old ubuntu 12.04lts and be detected as kodicom 4400, but on newer ubuntu 16 and later, that fix is no longer working, i tried google but all tutorials are old now, my 12.04 is getting old now and some apps starts to stop its support
bergenst
Re: Kodicom card on ubuntu 16.04 or latest
Post by bergenst »
Oh well, I fixed it myself, for reference:
The fix for some unrecognized kodicom card "unknown generic" in the bttv line when you type "dmesg" in the terminal, by creating a modprobe.conf file to /etc/modprobe.conf and pasting a line of
alias char-major-81 bttv
options bttv gbuffers=16 card=133,132,133,133 tuner=4,4,4,4
Inside the modprobe.conf only works with older versions of ubuntu usually 12.04 or older, to fix newer version of ubuntu like in 16.04, they have change the directory structure, its now /etc/modprobe.d, so you have to put the modprobe.conf into like "/etc/modprobe.d/modprobe.conf, along the pasted code inside it, now it works
