FOSCAM fi9828p installation
lblokland
Post by lblokland » Mon Apr 02, 2018 1:45 pm
I'm trying to setup the fi9828p from Foscam, but i cannot get PTZ to work.
I'm new with ZoneMinder, and was hoping anyone can help me out.
Cheers!
rksharma
Re: FOSCAM fi9828p installation
Post by rksharma » Wed May 02, 2018 6:24 pm
Might be bit irrelevant but can anyone please confirm ifs Foscam iOS app working on iOS 11.4 or not for the app is crashing on my end any help?
lovelash
Post by lovelash » Wed May 29, 2019 10:35 pm
This is one of the most common problem user faces. I was having the same issue, so in order to resolve it, just follow the mentioned steps (it worked for me)
1. Un-install the app
2. Delete the cache and other files of the apps (do it via file manager)
3. Restart your phone
4. Re install the app
and the issue will be fixed. Do let me know if you are having problem performing the steps which I have mentioned above or if the problem is still there. Would love to help! :)
Regards,
9Apps Vidmate https://get-cartoonhd.com
kumars
Post by kumars » Fri Jun 21, 2019 9:53 am
I tried setting up Foscam but it did work out with other process. Check out this information on walmart eye center hours
