Has anyone had any luck with this camera that is supposedly ONVIF capable. Any advice greatly appreciated!
Features:
Wi-Fi/802.11/b/g/n , Free Factory DDNS
Support Protocol: TCP, UDP, IP, HTTP, SMTP, DHCP, DNS,ARP, ICMP, POP3, NTP, IPSec UpnP, RTP, and RTCP
Dual stream encoding / H.264 compression mode
Night Vision:5-30m
2MP:1920*1080
Support Multi-Screen software and CMS
Onvif Compatibility
Wireless, P2P, Support Andorid iphone
Support IR-Cut
Supports Android and Apple phones
Support P2P
Support Onvif Protocol
Here's the link:
https://www.aliexpress.com/item/ip-came ... 37596.html
JIENU 1080 IP Camera from AliExpress
Re: JIENU 1080 IP Camera from AliExpress
It's working! The only problem is that the video is pink!
