Hi all!
I have a Kodicom 8800 clone, same like pictured here
I have 6 no-name analog cameras with PAL standard. They are working just fine with very cheap Chinese DVR. They give color picture during the day and black and white during the night. Unfortunately when used with that card and Zoneminder i can only get them to work with setting "PAL Nc". But in that setting screen is B&W. I tried using every of PAL subtypes but screen gets garbled like here:
I tried settings from here https://wiki.zoneminder.com/Kodicom_8800 but then don't work. If I leave options unchanged it is detected and works fine but without color.
Do you have any tips about this?
Thanks and regards,
Michał
Colour missing on Kodicom 8800 clone
Re: Colour missing on Kodicom 8800 clone
In addition to settings, the hardware of the capture card will need to be able to decode PAL color encoding' are you sure that Kodi card can? Spec sheet or similar?
That is good question but this card was bought used and had only generic cardboard box, no specs or anything. I googled but I didn't find anything about color support.
Do you have any sort of NTSC camera available at all to feed to it?
I know what you are trying to check but unfortunately no NTSC hardware at all. I am trying to get some information from the seller if he ever achieved colour with PAL cameras.
Thanks,
Michał
Thanks,
Michał
