SunEyes SP-P901W
rangerbob
SunEyes SP-P901W
Post by rangerbob » Thu Dec 03, 2015 2:30 am
I am trying to get this to work
I have found numerous tid bits of info
https://www.ispyconnect.com/man.aspx?n=Suneyes
SP-P901W FMPEG rtsp://IPADDRESS:554//11
maybe I just do not have the experience hoping someone could get me to try or push me in the right direction. I have done alot of usb web cams and dvr card with tvl type analog cameras.
I have worked with foscam crappy and trendnet and axis and a few more but usualy they are well documented with what the configuration is. I am running the latest on a centos install with 1.28
I have been trying the http simple and numerous different ways to enter the credentials with //11 for the path or /554/11
rtsp://admin:mypass@192.168.1.18:554//11
rtsp://192.168.1.18:554/user=admin&password=mypass&-chn=2
rtsp://192.168.1.18:554/cgi-bin/hi3510/snap.cgi?user=admin&password=mypassm&-getstream&-chn=2
the most I am able to get is a blue screen (i actually got excited its been blank through most of my attempts)
now this camera supports rtsp streaming and according to the aliexpresspage I bought it from
rtsp://192.168.1.18/554/11 has anyone worked with suneyes cameras that are IP?
maybe what I need is someone who has experience with ffmpeg
rangerbob
Re: SunEyes SP-P901W
Post by rangerbob » Thu Dec 03, 2015 2:33 am
http://www.aliexpress.com/snapshot/7094 ... 4663727172
not sure how long this web page will be active but you can see what I bought.
rangerbob
Post by rangerbob » Tue Sep 06, 2016 2:50 am
Good news I figured out how and what alot more info and it works.
not tried everything.
I was in the web interface and I used the Inspect element (right clicking in firefox) option and I was able to narrow down the code to this
/cgi-bin/hi3510/snap.cgi?&-getstream&-chn=2
now with
http://admin:passwhateverip@/cgi-bin/hi3510/snap.cgi?&-getstream&-chn=2
I am able to get a decent video from firefox.
the rest I just pluck into the remote section of zoneminder
source is remote
simple http
remote host name is the ip
then this cgi line for the path and port 80 unless you changed it.. and enter the resolution you have it set to and thats it..
interesting the snap.cgi gives interesting things when you try to mess with the path.. like
http://admin:pass@ipaddress/cgi-bin/hi3510/snap.cgi?&
var path="/tmpfs/snap_tmpfs/20160906/IMG001/IMG_chn0_TIMER_MNG_20160906102703_001.jpg"
[Error][Data-Length:159] unrecongnized or incomplete command line. USAGE: snapcfg {-act set|list|snap} [-chn chnID] [-qval qval] [-pre presnap_num] type "snapcfg -?" to get help
searching for /cgi-bin/hi3510/snap.cgi brings up all sorts of intresting things.. i wounder if someone has a listing of the complete commands and options?
rangerbob
Post by rangerbob » Tue Sep 06, 2016 3:03 am
note this is still being sold. I have had it down to peeking at -28 C and peek 40C In canada Toronto area.
https://www.aliexpress.com/item/SunEyes ... 69108.html still seems to be sold https://www.aliexpress.com/item/SunEyes ... 69108.html https://www.aliexpress.com/store/201258 SunEyes official store on Aliexpress
the down side is this camera seems to want to connect all the time to ec2-54-186-48-247.us-west-2.compute.amazonaws.com:32100 I have firewalled it. (creapy)
rangerbob
Post by rangerbob » Tue Sep 06, 2016 3:07 am
note that Ip using the gateway I have allowing me to run iftop I can see it tries to connect to protocol bf-master (more creapyness) but the cam is great quality Have not played beyond getting it to work recently just wanted to let folks know
rangerbob
Post by rangerbob » Sun Jun 30, 2019 3:24 am
I figure I should let you know this camera is dead it dies after a few cold winters. I kept them to analyse what actually died on it. Will let you know when I eventually rip it apart. Note this is the second one to go
Users browsing this forum: burger, Majestic-12 [Bot] and 4 guests
