Kodicom 4400R Card not working
wheeliebin
Post by wheeliebin »
Hi
Just purchased a kodicom 4400R card and installed it in a box with a new install of Ubuntu 12.04 and am intending using it with ZoneMinder.
I have connected a camera to cam0 on the card
I have run "modprobe bttv gbuffers=16 card=133,132,133,133" and then run "xawtv" to check that the hardware is functioning but I get an error:
vid-open-auto:failed to open a capture device
no video grabber device available
presumably I should be able to see video0 etc in /dev? I cant..
Is it likely that the card is dead or have I missed out a step (I believe the driver is in the kernel and the modprobe command should have loaded it)
Be grateful for any assistance
chippy99
Re: Kodicom 4400R Card not working
Post by chippy99 »
Try creating a file called /etc/modprobe.d/bttv.conf containing
alias char-major-81 bttv
options bttv gbuffers=16 card=133,132,133,133 tuner=4,4,4,4
reboot and see if you have any /dev/video* files.
If not type dmesg | grep bttv to find any errors
wheeliebin
Thanks for the help.
I have done as you suggested.
After reboot there are no /dev/videoX files
dmesg | grep bttv produces no output!!
Have looked through dmesg | more and cant see anything glaringly wrong
Any more ideas gratefully received
wheeliebin
Solved.
Thanks for your help.
I saw bttv was loaded using lsmod, couldn't see any errors in any logs.
I unloaded bttv with rmmod and reloaded it (with -v) to see if there were any errors. None reported
Ran xawtv again and it worked.
