2 Megapixel IP Camera on ebay
racelife
Post by racelife »
http://www.ebay.com/itm/150708832760?ss ... 1439.l2649
anyone have this working or can someone give me some hints on how to probe around to find the stream?
lostboy
Re: 2 Megapixel IP Camera on ebay
Post by lostboy »
Did you get this camera working?
racelife
Post by racelife »
I haven't yet. I'm not sure where to start. I got sidetracked.
rphenix
Post by rphenix »
Try using nmap or similar to scan for open ports on the camera it mentions it supports rtsp so id be giving that a go personally.
You could try using wireshark to capture data between your pc and the camera when trying rtsp in vlc to get a hint for the correct settings.
beiber
Post by beiber »
This is seem to be good and if it is okay,i really wanted to buy it. :)
Today is the tomorrow you worried about yesterday.. for tomorrow never comes.. live today!!!
