Dual Card System
xxMOISESxx
Dual Card System
Post by xxMOISESxx » Tue Feb 15, 2011 7:24 pm
Hi guys,
I was wondering if it's possible to have a System with 2 different cards (Kodicom 4400 and Geovision GV800 16ch each). Is this possible? any hardware requirements or conflicts?.
Thanks in Advance.
timcraig
Post by timcraig » Wed Feb 16, 2011 12:58 am
As long as the Linux kernel has drivers for those cards, they should work.
An issue you might have is the /dev/video[number] mapping is different every time after a system reboot.
If that's the case, you can force the mapping or have the system create symbolic links with names of your choosing (e.g. /dev/geovision0, /dev/kondicom0) using udev rules.
xxMOISESxx
Post by xxMOISESxx » Wed Feb 16, 2011 7:15 pm
Thanks Tim.
I'm still not sure if I'll have to do this, but it's good to know that it is possible (as I suspected). I'll be back here for sure if I have to setup the system.
mainterpet
Re: Dual Card System
Post by mainterpet » Mon Mar 28, 2011 7:07 pm
ATI Crossfire and Nvidia quad sli. Yes, I would personally get the same card. Both require specific system boards, of course. For example for Nvidia sli should be able to Board. Most of new motherboards support crossfire. With regard to food once you narrow down the Board to purchase, you can go from there.
Users browsing this forum: No registered users and 5 guests
