Hikvision IP camera problem
hi everyone,
i tried to use Hikvision DS-2CD886MF ip camera as Remote with ZoneMinder, but i can't find Remote Host Path, has anyone know it?
Well, i connected to camera through telnet and don't find any .jpg, .mpeg, or .cgi files, but i find file video0 in directory /dev (/dev/video0).
(Camera has linux busybox file system)
any ideas?
(maybe mount somehow /dev/video0 from camera to my host, i don't know how)
any ideas?
Does the web-interface stream video? If so, just look at the source of the web-page... that will give you a clue of how it's loading the stream. If you see something enclosed in an <img></img> tag, you may be looking at an MJPEG stream for example.
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
Here is the code from http://cam_ip_addr/NetVideoOCX.htm
, but its not very helpful.
Well HikVision can also stream through RTSP (port 554) - i tried it with VLC-player (rtsp://cam_ip_addr) - it request login/pass, but then there was just black screen
<html>
<head>
<title>Net Viewer</title>
<SCRIPT>
function workaround()
window.document.all.item("ocx").style.display = "none"
window.document.all.item("ocx").style.display = ""
</SCRIPT>
</head>
<form><WINDWEB_URL>
<input>
</form>
<body>
<div>
<table>
<tr>
<td>
<object>
</object>
<script>
//document.activex.url.value="https://192.0.0.227"
document.activex.url.value=document.URL
var OCXobj = document.getElementById("NetOCX");
OCXobj.SetServerIP(activex.url.value)
if (screen.width<=800)
table.width=1004;
table.height=600;
NetOCX.width=1004;
NetOCX.height=600;
else
table.width=screen.width - 22;
table.height=screen.height - 166;
NetOCX.width=screen.width - 22;
NetOCX.height=screen.height - 166;
</script>
</td>
</tr>
<center>
</table>
</div>
</body>
</html>
<html>
<head>
<SCRIPT>
</SCRIPT>
</head>
<form><WINDWEB_URL>
<input>
</form>
<body>
<div>
<table>
<tr>
<td>
<object>
</object>
<script>
table.width=1004;
table.height=600;
NetOCX.width=1004;
NetOCX.height=600;
else
</script>
</td>
</tr>
<center>
</table>
</div>
</body>
</html>
Re: Hikvision IP camera problem
did you ever figure this out?
FWIW I have a HIKVision dome camera working in Zoneminder using FFmpeg.
The source path is; rtsp://admin:12345@192.168.0.13:554/St ... nels/1?tcp
ralph179, thanks for the help. It took almost 2 months for the new camera to get here but your url and advice to use ffmpeg worked.
Thanks again.
Thanks again.
Users browsing this forum: No registered users and 16 guests
