kodicom 8800
arielf
kodicom 8800
Post by arielf »
hola lista,, voy a escribir en espñaol , ya qie mi ingles no es bueno
Tengo una tarjeta kodicom 8800 como la que esta en el link de abajo
http://198579.en.ec21.com/8CH_DVR_Card_ ... 65869.html
ya esta funcionando y detectada como bttv878 , pero tambien la tengo instalada en windows y la calidad de imagen en windows es muy superior a la que me muestra en linux Centos 5.3 + Zm 1.24.1
no se si estara mal configurada , abajo les dejo el detalle de mi modprobe.conf
options bttv gbuffers=16 card=77,77,77,77,77,77,77,77 radio=-1 tuner=4
alias char-major-81 bttv
options i2c-algo-bit bit_test=1
lsmod
lsmod | grep bttv
bttv 164533 3
video_buf 27205 1 bttv
ir_common 31813 1 bttv
compat_ioctl32 5569 1 bttv
i2c_algo_bit 12489 1 bttv
btcx_risc 8777 1 bttv
tveeprom 17873 1 bttv
i2c_core 23745 6 i2c_ec,tuner,bttv,i2c_algo_bit,i2c_i801,tveeprom
videodev 25793 4 bttv
v4l2_common 24385 3 tuner,bttv,videodev
La camaras son marca siera con ccv Philips PALN.
gracias
arielf
Kodicom 8800
Post by arielf »
hello list, I will write in espñaol, qie and my English is not good
I have a 8800 card kodicom like this on the link below
already running and detected as bttv878, but also have it installed on windows and windows in image quality is much higher than shown on my linux Centos 5.3 + zm 1.24.1
not be wrong if configured, leaving them down the details of my modprobe.conf
gbuffers = 16 options bttv card = 77,77,77,77,77,77,77,77 radio tuner =- 1 = 4
options i2c-algo-bit bit_test = 1
lsmod
lsmod | grep bttv
bttv 164533 3
i2c_core 23745 6 i2c_ec, tuner, bttv, i2c_algo_bit, i2c_i801, tveeprom
v4l2_common 24385 3 tuner, bttv, videodev
The cameras are brand Siera Philips paln with CCV.
thanks
johnnytolengo
Post by johnnytolengo »
proba con esta configuracion:
options bttv gbuffers=2 card=102,102,102,102,102,102,102,102 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
por ahi te mejora un poco, yo tengo el mismo problema pero la imagen safa bastante.
despues avisa.
chau.
kylejohnson
Post by kylejohnson »
As the previous poster said, try using the 'card=102'.
I have the same card in one of machines and use the following and my images look good:
options bttv card=102,102,102,102,102,102,102,102
