intellinet 550291 opensuse 11.1 zm 1.24.1
aberto
Post by aberto » Mon May 25, 2009 3:01 pm
When I start the monitor I see a black screen.
My settings:
remote host name: ext_uno
port: 80
remote host path: 192.168.1.221
remote host sub path: jpg/ext_uno.jpg
color depth: 24
image width: 352
image height: 288
My zm log:
05/25/09 16:39:05.179692 zmc_m1[17937].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /var/log/zm/zm_debug.log.17937]
05/25/09 16:39:05.180811 zmc_m1[17937].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
05/25/09 16:39:05.374828 zmc_m1[17937].FAT-zm_remote_camera.cpp/67 [Can't gethostbyname(ext_uno): Operation not permitted]
My zm log:
05/25/09 17:55:12.285971 zmc_m1[19466].DB3-zm_remote_camera_http.cpp/692 [Got connection 'Keep-Alive']
05/25/09 17:55:12.286000 zmc_m1[19466].DB3-zm_remote_camera_http.cpp/698 [Got content length '32']
05/25/09 17:55:12.286029 zmc_m1[19466].DB3-zm_remote_camera_http.cpp/726 [Got content type 'text/plain']
05/25/09 17:55:12.286058 zmc_m1[19466].ERR-zm_remote_camera_http.cpp/768 [Unrecognised content type 'text/plain']
05/25/09 17:55:12.286356 zmc_m1[19466].ERR-zm_remote_camera_http.cpp/1042 [Unable to get response]
05/25/09 17:55:12.286439 zmc_m1[19466].ERR-zmc.cpp/258 [Failed to capture image from monitor 1 (0/1)]
My zmwatch.log (obviously):
05/25/09 16:22:40.754221 zmwatch[15211].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
apache error.log is clean
if I change the hostname with the ip:
My zm log:
05/25/09 16:59:36.157129 zmc_m1[18318].ERR-zm_remote_camera_http.cpp/682 [Invalid response status 404: Not Found]
thanks for help
kingofkya
Post by kingofkya » Mon May 25, 2009 5:54 pm
see documentation on shared memory then post if you have problems
kingofkya
Post by kingofkya » Mon May 25, 2009 5:56 pm
http://www.zoneminder.com/wiki/index.php/Documentation
kernel.shmall = 134217728
kernel.shmmax = 134217728
aberto
Post by aberto » Mon May 25, 2009 6:46 pm
ipcs -l output
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 4194303
max total shared memory (kbytes) = 1073740800
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 1024
max semaphores per array = 250
max semaphores system wide = 256000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 422
max size of message (bytes) = 65536
default max size of queue (bytes) = 65536
shared memory seem to be ok (I need 40*24*352*288),
cambozola.jar and other settings don't change the result.
I can see the camera using the web manager (http://address) and download image with wget. Other?
monex
Post by monex » Wed May 27, 2009 6:27 pm
it looks like it's not a shared memory issue because your first error is Unrecognised content type 'text/plain'. I guess you have configured your camera wrong. Did you specify the IP address with http://ip because also gethostbyname failed. Try to us only the IP address without http://
Hope this helps
aberto
Post by aberto » Thu May 28, 2009 6:25 am
I tried both configurations, as you can see in my first post the error appears with the configuration that should be corrected. I tried also to exclude the firewall without success. I am beginning to think that depends on the netcam.
kingofkya
Post by kingofkya » Thu May 28, 2009 9:40 pm
ok i see prob
try
remote host sub path: /jpg/ext_uno.jpg
the slash
aberto
Post by aberto » Fri May 29, 2009 9:57 am
I tried it, same problem. I'm trying to setup on another pc, maybe depends on the chipset of the mainboard.
kingofkya
Post by kingofkya » Fri May 29, 2009 2:33 pm
mke sure
http://<camIP>/jpg/ext_uno.jpg
relly works in web browser
aberto
Post by aberto » Mon Jun 01, 2009 8:47 am
I installed everything on another PC, now it works (with: http://<camIP>/jpg/ext_uno.jpg). When I understand why it did not work I replay on this post. Tanks for the help.
Users browsing this forum: No registered users and 10 guests
