Suggestions needed - Off-Shore project
PalliSteina
Post by PalliSteina »
Hello everyone.
I'm a technician for Marine Research Institute of Iceland. We are currently working on a project that requires recording fish behavior around a feeder system we are building.
The plan:
We will place a buoy into a remote fjord. In the buoy is an advantech computer that will act as a control unit/server running CentOS. From the buoy is an umbilical cable connecting the devices on the seabed(150m down). We will use Kongsberg camera that outputs analog signal.
What I need to know:
To be honest, I'm not sure if ZoneMinder is the right application for us. But if it can capture based on movement or timing and has adequate video logging I believe it should work.
What would be the best capture card to use? We will be using 2 cameras later on so 4 inputs should be what Im looking for. The card needs to be PCI and low power(if possible) but I want quality. Anyone recommend this card? Spectra8
Any suggestions are wellcome, I'm bit out of my element right now. :)
Regards,
Palli
Lee Sharp
Post by Lee Sharp »
Your issues will be in administration. If it reboots in a database write, you will corrupt the database and no more recording, for example.
As to cards, I would get a single chip 4 port card. The BT878 chips run very hot, which means they use a lot of power. Would 11fps do it? A single chip will do 2 cameras at 11fps all day long.
Lee Sharp
Post by Lee Sharp »
You can stop the ZM service, and run a mysqlcheck via cron, then restart the ZM service. That limits your exposure to 1 day max. (Or hourly, if you really want. Generally it takes less than 3 minutes.
And yes, a UPS and good hardware minimize it. I just always plan for the worst so I don't get surprised.
