I have promoted linux and specially ZoneMinder for those people that has a poor windows DVR system (as always windoze crash, etc)
Well, now I stay in a problem. All capture cards has some clients are incompatible with linux, or at least I can't found the proper driver.
As an example, one of those cards cost 1200 dollars, has 16ch at 480fps, etc.
I am very frustrated to run these cards with ZM.
This is the case of DIGIFLOWER DF-9100. You can see this board at:
http://www.dfdvr.com/
The board has four input chips, one for each four cameras. Those are TECHWELL TW2804
And the main procesor is ALOGIC AM7416 ( http://www.alogics.co.kr/en/pro/7416.htm )
I have installed this card under XP to see what driver use, and this is the content of the DF_9xxx.inf file. Also I have the .sys file.
[Version]
Signature=$CHICAGO$
Class=MEDIA
ClassGUID={4d36e96c-e325-11ce-bfc1-08002be10318}
Provider="DFDVR" ;%str_Provider%
[SourceDisksNames]
1="",,
[SourceDisksFiles]
DF_9xxx.sys=1
[DestinationDirs]
CopyVideoFiles = 10,System32\Drivers
[Manufacturer]
%str_Manufacturer%=ALOGIC_SECTION
[ALOGIC_SECTION]
%VEN_1999&DEV_A900%=AM74AP08_Install,PCI\VEN_1999&DEV_A900
%VEN_A123&DEV_A000%=AM74AP08_Install,PCI\VEN_A123&DEV_A000
;;;;;;;;;;;;;;;;;;;;;window 2000 Video ;;;;;;;;;;;;;;;;;;;;
[AM74AP08_Install.NT]
CopyFiles=CopyVideoFiles
[AM74AP08_Install.NT.Services]
Addservice = AM74AP08, 0x00000002, AM74AP08_AddService
[AM74AP08_AddService]
DisplayName = %str_AM74AP08%
ServiceType = 1 ; SERVICE_KERNEL_DRIVER
StartType = 3 ; SERVICE_DEMAND_START
ErrorControl = 1 ; SERVICE_ERROR_NORMAL
ServiceBinary = %10%\System32\Drivers\DF_9xxx.sys
;;;;;;;;;;;;;;;;;;;;Common Item ;;;;;;;;;;;;;;;;;;;;
[CopyVideoFiles]
DF_9xxx.sys
[Strings]
str_Provider ="DFDVR"
str_Manufacturer ="DFDVR"
VEN_1999&DEV_A900 ="DF-9xxx Device(AM7416 & PCI Bridge)"
VEN_A123&DEV_A000 ="DF-9xxx AM7416 Device(AM7416 & PCI Bridge)"
str_AM74AP08 ="DF-9xxx AM7416 Driver(AM7416 & PCI Bridge)"
05:01.0 Multimedia video controller: Unknown device 1999:a900 (rev 01)
05:01.0 Class 0400: 1999:a900 (rev 01)
Flags: bus master, slow devsel, latency 64, IRQ 201
Memory at faffdc00 (32-bit, prefetchable) [size=1K]
Is there a chance to make a drive for linux from XP driver? Sorry for the stupid question.
regards
Normando
