Serial over LAN - Serial Device Server
robi
Post by robi » Thu Dec 27, 2007 8:58 pm
A gadget like this, (for example the Tibbo DS100 Serial Device Server) is nothing more than a standard serial port, that can be located anywhere in your network. It can be accessed by any computer in the network by installing a "Virtual COM Port" in the operating system - drivers for Linux are available. This way, the serial port is no longer stuck with the computer, it can be anywere in the (inter)net - very useful (yes, even forwading through routers and stuff possible!).
In my case, the ZM box is very far from the location where I'd put a panel with LEDs and Switches - and if Serial is the way to go, this Serial Device Server would be my solution.
Check it out: http://www.tibbo.com/ds100.php Extensive documentation is available.
Image Image
Applications: alarm visualisation, ptz, remote controlling, external event trigger capturing...
Opinions?
v1.25.0 + Ubuntu Linux 12.04 Server
craver84
Post by craver84 » Mon Jan 11, 2010 11:01 pm
I've just bought a DS100.
Can you please tell me how to send signal to the serial port?
StanKu
Re: Serial over LAN - Serial Device Server
Post by StanKu » Tue May 10, 2016 12:39 pm
You may access your serial port over LAN with the software solution http://www.eltima.com/serial-over-lan.html. It doesn't need any hardware devices to work with your existing COM ports, and may even create virtual ones. :!:
