Need a KNOWN GOOD hardware recommendation
phrak9
Post by phrak9 » Thu Dec 27, 2007 6:31 pm
I have been battling with a x86-64 system that continues to have problems. I have an older 32 bit system that has no problems whatsoever. The system is being rigged with 8-9 cams. I would appreciate some input on some proven available hardware that I can rely on. :)
Lee Sharp
Post by Lee Sharp » Thu Dec 27, 2007 9:10 pm
I have built a few with the Gigabyte P35 based motherboards. Essentially any inter chipset should work with any capture card out there. Other chipsets occasionally have issues with some cards. You may want to try your existing hardware with the capture card in another slot. Disabling all unused items and resetting ECSD can also help.
Or, if you want, I can build you one with ZM installed and configured. It will be on a cost + basis to cover my time and a donation to ZM. Obviously you have to decide if shipping from Houston is worth it, as you have no location in your profile.
ammaross
Post by ammaross » Thu Dec 27, 2007 9:43 pm
Gigabyte mobos, from past experience, can be very particular about their RAM, so make sure you stick exactly to their HCL for memory.
robi
Post by robi » Fri Dec 28, 2007 4:21 pm
ammaross wrote:Gigabyte mobos, from past experience, can be very particular about their RAM, so make sure you stick exactly to their HCL for memory.
However Gigabyte mobos are _very_ reliable and long-life products. I state that based on my personal experience. Several Gigabyte generations...
v1.25.0 + Ubuntu Linux 12.04 Server
ammaross
Post by ammaross » Fri Dec 28, 2007 10:55 pm
Yes, I try to use Gigabyte exclusively because of that. To maintain their reliability, they are very strict on their RAM support and it is advisable to strictly adhere to their HCL.
Users browsing this forum: No registered users and 7 guests
