Page 1 of 1
Combining a dome camera with motion detection and ZM?
Posted: Wed Sep 07, 2005 3:35 pm
by ekiboy69
Has anybody tried or even considered the following: what about using a dome camera that has a built-in motion detection? I have heard that Panasonic has a model that is able to "follow" (pan & tilt) moving objects. This feature would in my opinion be a killer app combined with ZM.
I'll dig the model up and post it here.
Still missing the essential information
Posted: Thu Sep 08, 2005 5:50 am
by ekiboy69
The make and model of the camera is Sony SNC-RZ30P.
http://www.sonybiz.net/netstation%5E/te ... &OID=78391
I am still waiting for an asnwer from a user whether the camera actually is able to follow movement.
False information - the camera does not follow motion
Posted: Thu Sep 08, 2005 8:55 am
by ekiboy69
Hei,
I just received a comment of a user of the Sony camera mentioned above. The camera does not follow moving objects.
Are there any cameras able to do that?
Posted: Thu Sep 08, 2005 9:16 am
by jameswilson
bosch make a dome ptz that does but its about 2k and need rs485 Never used one though
James
2k but what currency?
Posted: Fri Sep 09, 2005 5:27 am
by ekiboy69
2k but in what currency?
Posted: Fri Sep 09, 2005 8:48 am
by jameswilson
pounds im afraid
Posted: Fri Sep 09, 2005 7:02 pm
by SyRenity
Hi.
AFAIK, the latest ZM includes such experemental feature to follow the moving objects. Check the docs for more info, and these threads:
http://www.zoneminder.com/forums/viewto ... t=tracking
Posted: Sat Sep 10, 2005 4:31 pm
by zoneminder
The feature won't continuously follow a moving object however when motion is initially detected it will turn the camera to center the motion until no more motion is detected whereby the camera will (optionally) be returned to a home orientation. It should work with any camera that can map image co-ordinates to pan/tilt instructions, this includes the Axis and Panasonic IP cams as well as (with a bit of calibration) any camera that allows a relative movement from the current orientation.
Phil
Extremely interesting
Posted: Mon Sep 12, 2005 4:02 pm
by ekiboy69
This feature looks very interesting. What would be the best buy of compatible low end cameras to test this out? I am talking about the models available in EU.
Posted: Tue Sep 13, 2005 12:59 pm
by zoneminder
Assuming you are talking about indoor cameras, and also assuming low-end means not dirt cheap, I would take a look at the Panasonic PTZ IP cameras. They have limited PTZ range to ok to put in a corner of a room and be able to turn to see anything that might happen.
Phil
