Slackware Installation Instructions
Ruler
Post by Ruler » Mon Dec 19, 2005 8:32 pm
I've created a HOWTO of sorts to install ZoneMinder on Slackware. These directions specifically reference Slackware 10.1 and ZoneMinder 1.21.3
http://www.zoneminder.com/downloads/VSS ... ummary.pdf
http://www.zoneminder.com/downloads/VSS ... etails.pdf
This message is made up of not less than 90% recycled electrons.
maniacul
Removing "nph-" from ZM_PATH_ZMS => streaming i
Post by maniacul » Thu Dec 28, 2006 7:49 pm
I'd also like to share something to the slackware users.
I installed & configured ZM only on more than 5 slack machines upto now, diferent versions of ZM, different versions of slack.
As somwhere else read on this forum, I recomend kernel 2.6.x as it gives better performance!
I'd also recomend lots of RAM (1gig) if higher number of cams (>4) & higher resolution (640x480).
MOST OF ALL:
!!! I could not get streaming images ONLY after I removed "nph-" from Options > Paths > ZM_PATH_ZMS !!!
Respect,
Dr.Septimiu Suciu
