Zoneminder & AMD64 systems
bridgebr
Post by bridgebr »
After a lot of time wasted, I think I found a solution. (AMD64) :idea:
Edit the file /usr/bin/zmdc.pl (#sudo gedit /usr/bin/zmdc.pl)
insert the following line: 8)
$ENV{LD_PRELOAD} = '/usr/lib/libv4l/v4l1compat.so';
this line should be inserted just before the "my @daemons = (" line
just restart zoneminder and it magically works ! :shock:
DaveQB
Re: Zoneminder & AMD64 systems
Post by DaveQB »
bridgebr wrote:After a lot of time wasted, I think I found a solution. (AMD64) :idea:
What problem is this solving??
