ffmepg options
Posted: Tue Jul 14, 2009 8:40 pm
I'm having trouble setting up ffmpeg to export video files from zoneminder. I've not found any guidance except on the main wiki page, which helpfully suggests you look at the ffmepg documentation!
If I download the jpg files in a tar file and unpack them I can create a video file with the following command (stolen from http://electron.mit.edu/~gsteele/ffmpeg/):
My best attempt to fit this command line into zoneminder's option fields goes like this:
which doesn't work!
Has anyone got this working, can you let me know the trick!
Thanks,
Luke
ffmpeg -b 1800 -i %03d-capture.jpg -vcodec mpeg4 out.avi
FFMPEG_INPUT_OPTIONS "-b 1800"
FFMPEG_OUTPUT_OPTIONS "-vcodec mpeg4"
Thanks,
Luke
