cordel
Post
by cordel » Fri Aug 03, 2007 10:06 pm
Yep they work okay, just make sure it has bt878 chip(s) The single chip types are usualy card=77
fxghosting
Post
by fxghosting » Fri Aug 03, 2007 10:09 pm
how can i tell? pictures are too low res and i doubt the seller can look
cordel
Post
by cordel » Fri Aug 03, 2007 10:12 pm
If you ask the seller and they don't reply, don't buy.
fxghosting
Post
by fxghosting » Fri Aug 03, 2007 10:22 pm
may just get one from bluecherry
cordel
Post
by cordel » Fri Aug 03, 2007 10:36 pm
Your second link has a Conexant chip on it. I would still ask and make sure it is a bt878 though. Since it's a single chip card, you can expect about 2.5 fps if all four ports are used. It strongly resembles a card I have used before, I would suggest for any card you buy, if the bt878 chips don't already have a heat sink, add one to each bt878 chip.
apcyberax
Post
by apcyberax » Tue Aug 07, 2007 5:53 am
i have that card it works ar between 2-4 fps witch is great for cctv.
n8jsn
Post
by n8jsn » Tue Aug 14, 2007 8:11 pm
Any chance you have the drivers for this card?
cordel
Post
by cordel » Tue Aug 14, 2007 11:06 pm
Drivers are available through their maintainers. We do not provide drivers here. Which card?
cyrulution
Post
by cyrulution » Sun Sep 02, 2007 1:31 pm
cordel wrote:Yep they work okay, just make sure it has bt878 chip(s) The single chip types are usualy card=77
How can I set up the card as 77?
Lee Sharp
Post
by Lee Sharp » Sun Sep 02, 2007 7:59 pm
In a case like your, just buy a ZM supported card. Then the vendor can tell you the steps for that card. It can vary. Based on your level of knowledge at this time, I recommend spending the extra money for a Blue Cherry card that comes with instruction.
apcyberax
Post
by apcyberax » Mon Sep 03, 2007 4:31 pm
n8jsn wrote:Any chance you have the drivers for this card?
no drivers needed for linux just need to edit the modprobe file
morpheus106
Post
by morpheus106 » Tue Sep 04, 2007 8:00 am
if i buy a card with chipset conexant fusion 878 4 channel can i connect 4 camera? They works all 4 or only 1?
P.s. sorry for my english
Lee Sharp
Post
by Lee Sharp » Wed Sep 05, 2007 4:11 am
Maybe. Some work and some don't. A lot of it is trial and error. We have a business, so we tried a lot of cards. I have a large box of cards I will sell you cheap that do not work in Linux. Some will work per chip, but not the additional channels. There is a infamous 16 port 8 chip card that no one has ever gotten more than 8 channels on with Linux. (It also has bleed and crappy video.) Some just do not, and will never work on Linux. (The Geovision cards and clones are a good example) If you had posted a picture of a card I had tried (a lot) I would have said so, and stated the settings I used. If you can not afford to take a chance, buy a know card. The card you pictured has a good chance of working, but I just don't know for sure.
morpheus106
Post
by morpheus106 » Wed Sep 05, 2007 9:23 am
Lee Sharp, i don't know how to attach an image in this forum, if you tell me your mail i can send to you the image of dvr card and you tell me if if a good card or not.
Thanks thanks
