Any recommendation for wireless PTZ ip camera?
tomlj
Post by tomlj »
I wish to set up a zm system based on wireless PTZ IP camera.
Would you please recommend me a model that is compatible with zm?
Thanks in advance.
Cheers,
tomlj
jameswilson
Post by jameswilson »
recommend axis. Cost a bit more but worth every penny
James Wilson
tomlj
Post by tomlj »
Thanks for your kind reply.
AXIS 213 and AXIS 214 are IP based PTZ camera. But they have no built-in wireless. Is there any camera model that support wireless, PTZ and IP and compatible with zm?
Cheers,
tomlj
jameswilson
206w if still around or the 207w
James Wilson
jameswilson
oopos sorry just spotted the ptz bit
dontthink there is a wireless ptz one, if i needed wireless then id use an access point. You can get a netgear access thing that is designed to make an xbox wireless. I have used one of these to make a zm box wireless before now. You would be able to plug your cam into this
James Wilson
lewis
Post by lewis »
Sony has also some excellent ptz cameras with superb optics..
i was playing with one, with 23x optical zoom, i could spot every landmark in the city i live..
Ye-Olde's Manor - http://ye-olde.net
Flash_
Post by Flash_ »
Also - recommended on here (by a dealer, if I remember, if that has any bearing) - Gadspot.
No personal experience, though I see the presets are in the current ZM release and that they work. PTZ, Infra-Red, indoor/outdoor. Relatively cheap and seem an attractive once you get scared by Axis' pricelist of the upper range.
Only downside in the specs I could see this morning - no PoE, but you can add that with a dongle anyway. They are 12v which is widely supported by PoE adapters.
