TRENDnet TV-IP851WC not working.
Noahe
Post by Noahe » Fri Aug 21, 2020 5:41 pm
This camera is giving me no end of grief. It makes no sense, I can get a MJPG stream with a URL in a web browser, but not in either VLC nor ZoneMinder. The following URL is tested and working in Firefox:
http://ipaddress/mjpeg.cgi
Using this address, the browser first asks for your username and password, then works.
http://username:password@ipaddress/mjpeg.cgi
Using this address, the browser has a pop-up that says "You are about to sign in to the site "ipaddress" with the username "username". If you click "OK" it works. Presumably neither VLC nor Zoneminder are going to click this.
Next, after some Googling, I turned off authentication. Then the first address works every time, no pop-up, no username or password. Yet still, the URL that takes me directly to the MJPG stream in a browser, doesn't work in either VLC or ZoneMinder.
Finally, to help anyone else out, I can confirm the following cameras are working just fine in ZoneMinder.
TRENDnet TV-IP110
TRENDnet TV-IP110W
TRENDnet TV-IP121W
TRENDnet TV-IP410
TRENDnet TV-IP410W
All of the above cameras work with http://username:password@ipaddress/cgi/mjpg/mjpg.cgi
Foscam R2
rtsp://admin:password@ipaddress:88/videoMain
iCan IPC-HS20S142
iCan IPC-HS20T297
Both of these work with rtsp://username:password@ipaddress/H264?ch=1&subtype=0
Tenvis T8805
rtsp://username:password@ipaddress:554/11
Vstarcam C7833WIP
rtsp://username:password@ipaddress:10554/udp/av0_0
Users browsing this forum: No registered users and 7 guests
