nest.com cam no connection
truderinger
Post by truderinger » Sun Jun 14, 2020 6:37 am
I use four cams via the nest.com cloud. I can directly access the camera through an internet browser. The link then looks like this:
https://video.nest.embedded/live/xxxxxx
Unfortunately I don't get a connection. Has anyone dealt with the Nestcam problem?
Thanks for an info.
best regards Herbert
truderinger
Re: nest.com cam no connection
Post by truderinger » Sun Jun 14, 2020 12:18 pm
I've come a little closer to my goal. Since the official browser stream could not be played in e.g. VLC either, I found a website that gave the actual address of the stream. This is "https://www.ispyconnect.com/userguide-nest.aspx". With this link I can now play the stream directly in VLC.
So I copy the stream link and enter it under ZM under Source. Target TCP-24bitColor-480x394. Before that, however, under General FFmpeg and Monitor. Voila, I can see the camera in ZM. Now I'm still trying to include this for Kodi with a ZM client.
best regards
truderinger
Post by truderinger » Mon Jun 15, 2020 7:36 pm
Hallo,
after long attempts with the registration problems from kodi 18.6 with the zm-addon, in Apache2 (zm / cgi-bin) I have now updated to Zoneminder 1.34 with API.2 out of desperation. Just changed the API in the addon to "2" and it works.
Zoneminder can be accessed directly via a browser, but no streams are displayed (Cams offline).
I think these are minor blemishes that need to be fixed.
best regards
gunfus
Post by gunfus » Mon Oct 19, 2020 3:37 pm
Has anyone tried this?
https://den.dev/blog/nest/
