SV3C B06POE-1080P-A
pjaffray
SV3C B06POE-1080P-A
Post by pjaffray » Tue Jun 19, 2018 10:10 pm
I didn't see this in any lists (mostly I found the B01... listed). I was able to finally get this to work under 1.30.4 using the ONVIF probe.
Source Type: Ffmpeg
Source path: rtsp://<adminid>:<admin-password>@192.168.x.x:554/stream0?username=admin&password=<hash of password>
Remote Method: TCP
Capture Width: 1920
Capture Height: 1080
I was able to view the camera via VLC using: rtsp://<admin-id>:<admin-password>@192.168.x.x/stream0 (or stream1), but not on my Mac, only from a Windows machine.
Hopefully this helps someone.
bt0
Re: SV3C B06POE-1080P-A
Post by bt0 » Tue Oct 02, 2018 1:18 pm
I had a problem getting this to work also. I finally got it working and added a section to the wiki:
https://wiki.zoneminder.com/SV3C
SV3C SV-B06POE-1080P-A
Server: None
Source Type: Ffmpeg
Analysis FPS, Maximum FPS, Alarm Maximum FPS all blank.
Source Path: rtsp://<username>:<password>@x.x.x.x:554/stream0 where x.x.x.x is the IP address of your camera
Remote Method: RTP/RTSP
Target colorspace: 24 bit color
Capture width: 1920
Capture height: 1080
snova
Post by snova » Fri Dec 21, 2018 8:32 am
I would like to share some of my experience with these.
1. If using POE, the DC INPUT jack becomes a DC OUTPUT jack. Good for powering external IR LEDs.
2. The IR sensor shuts off if you shut off the built in IR LEDS. So to use the external IR LEDs without also using the built-in IR (to avoid issues with bugs and reflection of rain, etc), I had to tape the built in IR LEDS.
3. H265 doesn't seem to go below 10fps analysis according to ZM, so I force it to H264.
Any other insights, troubles/workarounds , and anything else anyone wants to share to help me avoid other issues that people have run into, I would be happy to hear.
