i have a Floureon-IP-Cam (720P HD CCTV IP, SP012). I don`t got it run with zoneminder.
With VLC it`s no problem to see a stream with the opening below
rtsp://admin:888888@192.168.254.35:554/onvif1
Can anyone help to get the cam into zoneminder ?
Thx
Best regards
rhcam
Floureon IP-Cam
Re: Floureon IP-Cam
Try to check if your Floureon IP Cam is properly connected in your wireless router or if you assigned the correct IP address.
