Hi!
I own Dahua 3MP IP camera IPC-HFW2320R-ZS&VFS-IRE6 with motorised lense.
ZM 1.30 on Debian
The below settings works 100%, no stream interruptions, no image deformations
Settings on camera:
1 stream full 2048 X 1536 h.264 10 FPS
2 stream VGA (640 X 480) h.264 10 FPS
ZM-1.30 monitor settings for two streams:
Monitor-1 set up as modect stream 2 without linked monitors
Source Type: Ffmpeg, Analysis FPS: 10.0, Maximum FPS (?): 20.0, Alarm Maximum FPS (?): 20,0, Reference Image Blend %ge AND AlmRefImageBlendPct: 12,5%
Source Path: "rtsp://admin:passphrase@IP_of_camera/cam/realmonitor?channel=1&subtype=1", Remote Method: RTP/RTSP, Options (?): allowed_media_types=video, Capture Width (pixels): 640, Capture Height (pixels):480
Monitor-2 set up as nodect stream 1 and linked with monitor-1
Source Path: "rtsp://admin:passphrase@IP_of_camera/cam/realmonitor?channel=1&subtype=0", Remote Method: RTP/RTSP, Options (?): allowed_media_types=video, Capture Width (pixels): 2048, Capture Height (pixels):1536
At night the camera triggers alarms caused by "dancing worms", see viewtopic.php?f=31&t=22120#p98559 but this is not related to this camera only.
Have a clear view!
