Hello from NZ,
Have ZM1.3 running on Ubuntu 16.04 with 2 DLink cameras (DCS 4602EV) working well.
Now would like to hook up an Axis P1435-LE and an Axis P3225-LVE camera.
Have tried with various parameters but no go.
Haven't found anything in the forums for these 2 models either.
Can view stream in Firefox.
Any ideas of what parameters should work.
Thanks for any help.
Axis P1435-LE and Axis P3225-LVE -- need help
Re: Axis P1435-LE and Axis P3225-LVE -- need help
Zoneminder Parameters for Axis P3225-LVE & Axis P1435-LE
General Tab:
Source Type: Ffmpeg
Source Tab:
Source Path: rtsp://user:password@IP/onvif-media/media.amp?profile=profile_1_jpeg&sessiontimeout=60&streamtype=unicast
Remote Method: RTP/RTSP
Options (?): size = 1
Target colorspace: 24 bit colour
Capture Width: 1280
Capture Height: 960
Had to set up an ONVIF user in the axis camera (same user & password as to get access to camera) then could use the Zoneminder ONVIF button on the ‘General’ tab to read out the parameters. Worked like a charm.
Spent a lot of time to figure it out but won’t forget a hard learned lesson.
General Tab:
Source Type: Ffmpeg
Source Tab:
Capture Width: 1280
Capture Height: 960
