Hello Everyone,
i'm new to zoneminder and started with an Foscam FI9826P camera. Thanks to the wiki the stream setup ran quite smoothly. Sadly i didn't managed to get the contol of this camera running. I tried the older Foscam Control Scripts and the onvif support. So far no luck. Can anyone tell me if this thing is currently or will be supported?
Cheers,
Thomas
[Solved] FI9826P V2 Control Support ?
Re: [Solved] FI9826P V2 Control Support ?
...finally found a solution. The control with the protocol FI9831W runs very well (and if you correct the typo in us(e)r=xxx$pw=xxx )
