Zavio B8220 camera works with this parameters :
Source Type : Ffmpeg
Path : rtsp://camera_ip_address:554/video.pro1
Method : RTP/Unicast
Width : 1280
Height : 720
AND the "Profile1" (in the Zavio configuration) defined with the following parameters :
Coding : H264
Profil : BASELINE
Resolution : 1280x720
Frame Rate max : 30
Quality : Fixed quality "Excellent"
MaxBitRateFormat : 4M
Audio Stream : Off
ZAVIO B8220 Working
Re: ZAVIO B8220 Working
The result is better with Method : RTP/RTSP
The full configuration is :
Method : RTP/RTSP
Width : 1280
Height : 720
Coding : H264
Profil : BASELINE
Frame Rate max : 30
Audio Stream : Of
Method : RTP/RTSP
Width : 1280
Height : 720
Coding : H264
Profil : BASELINE
Frame Rate max : 30
Audio Stream : Of
