Heden CAMHD04MD0
framike
Heden CAMHD04MD0
Post by framike »
Hi All
Thanks for your experience which helped me to set my cam.
Here are my findings :
1./ IMHO do as much as possible settings directly in your hardware camera (I mean via its web interface)
in order to ease ZM job particularly if you run it on a slow server
my image is reversed BEFORE to reach ZM, it is also timestamped BEFORE. So I left the timestamp tab in ZM blank
2./ Settings :
Source type : FFmpeg
Source path : rstp://mylogin:mypassword@mycamIP
remote methode : RTP/RSTP
capture 640 x 352
Cehagenmerak
Re: Heden CAMHD04MD0
Post by Cehagenmerak »
Wonderful !
I just want to send a huge thanks to you, i've been searching for the settings of my Heden cam for days...
It seems to work fine, but can i ask how did you managed to get the right settings ?
Thanks a lot.
Ciao.
