I have an card with two chipset bt878A fusion and 16 inputs. Linux don't detect and when load module bttv i have this message (for one card):
[45293.019216] bttv: 1: Bt878 (rev 17) at 0000:12:0d.0, irq: 23, latency: 132, mmio: 0xd0002000
[45293.019223] bttv: 1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[45293.019307] bt878 #1 [sw]: Test OK
[45293.019947] tveeprom 7-0050: Huh, no eeprom present (err=-6)?
[45293.019949] bttv: 1: tuner type unset
[45293.020119] bttv: 1: registered device video1
[45293.020153] bttv: 1: registered device vbi1
I want to use'it with zoneminder but until cannot load properly i don't have any chance.
So, few specs:
lspci -vvnn
12:0d.0 Multimedia video controller [0400]: Brooktree Corporation Bt878 Video Capture [109e:036e] (rev 11)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 132 (4000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 23
Region 0: Memory at d0002000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Connection timed out
Not readable
Capabilities: [4c] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: bttv
regspy capture
BT878 Card [0]:
Vendor ID: 0x109e
Device ID: 0x036e
Subsystem ID: 0x00000000
BT878 Card - Register Dump:
BT848_IFORM: 49 (01001001)
BT848_FCNTR: 54 (01010100)
BT848_PLL_F_LO: 00 (00000000)
BT848_PLL_F_HI: 00 (00000000)
BT848_PLL_XCI: 00 (00000000)
BT848_TGCTRL: 00 (00000000)
BT848_TDEC: 00 (00000000)
BT848_E_CROP: 12 (00010010)
BT848_O_CROP: 12 (00010010)
BT848_E_VDELAY_LO: 1a (00011010)
BT848_O_VDELAY_LO: 1a (00011010)
BT848_E_VACTIVE_LO: e0 (11100000)
BT848_O_VACTIVE_LO: e0 (11100000)
BT848_E_HDELAY_LO: 82 (10000010)
BT848_O_HDELAY_LO: 82 (10000010)
BT848_E_HACTIVE_LO: d0 (11010000)
BT848_O_HACTIVE_LO: d0 (11010000)
BT848_E_HSCALE_HI: 00 (00000000)
BT848_O_HSCALE_HI: 00 (00000000)
BT848_E_HSCALE_LO: c1 (11000001)
BT848_O_HSCALE_LO: c1 (11000001)
BT848_BRIGHT: 14 (00010100)
BT848_E_CONTROL: 00 (00000000)
BT848_O_CONTROL: 00 (00000000)
BT848_CONTRAST_LO: cf (11001111)
BT848_SAT_U_LO: fe (11111110)
BT848_SAT_V_LO: db (11011011)
BT848_HUE: 00 (00000000)
BT848_E_SCLOOP: 40 (01000000)
BT848_O_SCLOOP: 40 (01000000)
BT848_WC_UP: cf (11001111)
BT848_WC_DOWN: 7f (01111111)
BT848_VTOTAL_LO: 00 (00000000)
BT848_VTOTAL_HI: 00 (00000000)
BT848_DVSIF: 00 (00000000)
BT848_OFORM: 06 (00000110)
BT848_E_VSCALE_HI: 60 (01100000)
BT848_O_VSCALE_HI: 60 (01100000)
BT848_E_VSCALE_LO: 00 (00000000)
BT848_O_VSCALE_LO: 00 (00000000)
BT848_ADC: 41 (01000001)
BT848_E_VTC: 00 (00000000)
BT848_O_VTC: 00 (00000000)
BT848_COLOR_FMT: 44 (01000100)
BT848_COLOR_CTL: 00 (00000000)
BT848_CAP_CTL: 00 (00000000)
BT848_VBI_PACK_SIZE: 90 (10010000)
BT848_VBI_PACK_DEL: 01 (00000001)
BT848_INT_MASK: 00000000 (00000000 00000000 00000000 00000000)
BT848_GPIO_OUT_EN: 0000b8ff (00000000 00000000 10111000 11111111)
BT848_GPIO_OUT_EN_HIBYTE: 00000000 (00000000 00000000 00000000 00000000)
BT848_GPIO_DATA: 00ffcd00 (00000000 11111111 11001101 00000000)
BT848_RISC_STRT_ADD: 00000000 (00000000 00000000 00000000 00000000)
BT848_GPIO_DMA_CTL: 00fc (00000000 11111100)
end of dump
Why cannot make this card to work?
Can someone help me?
P.S. On windows, this card work with software named Smartdvr formula maked by an company Intotech from Koreea.
