Dahua HFW4300S works
spiffybot
Post by spiffybot »
The setup is quite easy. I am using v1.26.4 on mageia 4
Pick Ffmpeg as source type.
Leave Maximum FPS and Alarm Maximum FPS blank. it just uses the same FPS as the camera stream is set to.
For the substream source
Path: rtsp://user:password@IPaddress:554/cam/realmonitor?channel=1&subtype=1
For the main stream subtype=0
Just using zoneminder to do the modect motion detection so I am looking at the 704x480 substream at 12 FPS. It performs very well. Don't need to modect on the HD stream unless you are looking for rats instead of people. I am using the filtered pixels method in the zone with the alarm pixels set at 150. Probably could go down to 100 pixels without too many false alarms.
