Raspberry Pi Cam module Streaming RTSP h264 video to ZM
jteeuw
Re: Raspberry Pi Cam module Streaming RTSP h264 video to ZM
Post by jteeuw » Mon Jun 02, 2014 12:45 pm
Thanks for the info!
but when i run the code , i get a couple of second the cam on my monitor and the a stops with a error ( see screenshot)
postfux
Post by postfux » Tue Jun 03, 2014 6:53 am
Hi jteeuw
Sorry now i know what was wrong in my Tutorial. Pleas forget my last post.
Instead of starting:
ffstream &
it schould be
sudo ffserver &
Once ffserver is running you should be able to start
raspivid -b 5000000 -ex night -mm average -op 150 -t 999999999 -w 640 -h 360 -fps 5 -o - |ffmpeg -v verbose -i - -flags +global_header -vcodec copy -r 5 -an http://0.0.0.0:8554/feed1.ffm
I corrected also the Tutorial at the beginning.
Greetings Markus
jteeuw
Post by jteeuw » Tue Jun 03, 2014 7:21 am
hi Markus,
Thanks you for the info , but when i run
sudo ffserver &
I get the following error :
jteeuw
Post by jteeuw » Tue Jun 03, 2014 7:23 am
jteeuw wrote:hi Markus,
sudo ffserver &
Found it , i run the following code to correct it :
sudo mkdir tmp2
postfux
Post by postfux » Tue Jun 03, 2014 8:11 am
Hi jteeuw
Glad to hear that i could help you and that you got it running!
Greetings Markus
jteeuw
Post by jteeuw » Tue Jun 03, 2014 1:39 pm
Hi Markus,
The stream is visible in VLC but in zoneminder i get the following errors:
postfux
Post by postfux » Tue Jun 03, 2014 7:32 pm
Hi jteeuw
Sorry i don't have so deep knowledge about zoneminder.
Have you compiled ZM by yourself ore used a prebuild version?
Do you use a 64bit Linux version? I have not used it for ZM,
so maybe when compiling you need different settings.
Greetings Markus
