DVB
mmesh
DVB
Post by mmesh » Wed Aug 14, 2013 7:51 am
There is a CCTV feed muxed into DVB-C channel on distributed TV system in my apartment building.
Does anyone know if YoneMinder is capable of recording a channel from DVB card?
I have a Raspberry Pi with USB DVB card setup and I can watch this channel in vlc or record with TVHeadend for example...
Flasheart
Re: DVB
Post by Flasheart » Thu Aug 15, 2013 6:59 am
Interesting.
Maybe. If you can manage to use ffmpeg to split out the stream, zm should be able to record it. (Set ffmpeg as the monitor type, and set the parameters in the source tab)
Failing that there may be some way to convert the image to a mjpeg or jpg stream using mjpeg-streamer or similar, or perhaps using vlc itself. ZM could then take a feed from that.
