Airlink101 SkyIPCam 747W - Working
Moderator: zoneminder
f15radar
Cant get it to work
Postby f15radar » Fri Aug 07, 2009 5:40 pm
I bought the 747 at Fry's for $99.00. Its the wired version. Anyways I can see it in the browser using http://user:password@xx.xx.xx.xx/cgi/jpg/image.cgi. I put in for host username:password@xx.xx.xx.xx, port 80, and for path /cgi/jpg/image.cgi. I set the resolution to 640x480. I am using Ubuntu 9.04 and Zoneminder 1.23.3. All I get is a black picture. Any help would be appreciated. Thanks in advance.
bill.schuller
TRENDNet TV-IP422(w) MJPEG Support?
Postby bill.schuller » Fri Aug 21, 2009 3:41 am
I saw in this thread that the TRENDNet firmware had been updated to correct the MIME Type issuse in the MJPEG feed. I'm running the latest version of the firmware (1.0.0 build: 71) on a IP422W without success. Has anyone had success with a different firmware version?
The trendnet version of these cameras have a new firmware that uses a Zoneminder supported mjpg stream so you might want to look at the trendnet cameras instead.
MarkG
Re: TRENDNet TV-IP422(w) MJPEG Support?
Postby MarkG » Fri Aug 21, 2009 6:07 pm
bill.schuller wrote:I saw in this thread that the TRENDNet firmware had been updated to correct the MIME Type issuse in the MJPEG feed. I'm running the latest version of the firmware (1.0.0 build: 71) on a IP422W without success. Has anyone had success with a different firmware version?
Note that there are two different MJPEG urls now, at least on my AIC500 camera.
mjpeg.cgi - the 'special' format with embedded camera info.
mjpg.cgi - the 'standard' MJPEG format
I haven't tried video with Zoneminder yet, but with the new firmware both Firefox and MythTV can stream live video using the mjpg.cgi URL.
bill.schuller
Postby bill.schuller » Sat Aug 22, 2009 4:00 am
MarkG wrote:mjpg.cgi - the 'standard' MJPEG format
The mjpg.cgi URL worked perfect in ZM 1.24.1. Thanks for the tip!
PRDR
Postby PRDR » Sun Aug 23, 2009 5:58 pm
I just wish I could flash the Airlink-777W camera with the Trendnet firmware...
MarkG
Postby MarkG » Sun Aug 23, 2009 6:44 pm
PRDR wrote:I just wish I could flash the Airlink-777W camera with the Trendnet firmware...
Have you tried bugging their support guys to release a firmware upgrade, as they already have for the AIC500? The code exists and they're clearly capable of getting it, so if it means more sales for them...
PRDR
Postby PRDR » Mon Aug 24, 2009 12:43 am
You're right. I had given up on support guys, but it's worth a try...
DONE, let's see if they care...
:oops: Guys, I feel really stupid... Right after writing to the support ppl, I tried the url /cgi/mjpg/mjpg.cgi, and guess what, it worked! It seems to have always been there. Actually, I tried it with an Encore camera which has pretty much the same web interface as the 777W, and it worked too... So, we have always had a working mjpeg stream... :lol:
I hope my e-mail at least helps on the noisy-audio-over-wireless issue...
jmirabil
Postby jmirabil » Wed Aug 26, 2009 2:39 am
Beware, the Airlink tech support folks, while they try to help, have no NEW firmware to offer at all--it is totally lame. The Trendnet version of the AICN777W is up to FW rev like .71, versus .19 shipping, and the .25 does help--but even Airlink will say they wont support you if you goto the .25 firmware from page three of this forum. Basically really really crappy support. this camera is oem'ed by so many manufacturers i wish the oem would just step up and help us. it REALLY STINKS!
Definitely bug them for a firmware update--bug them on one of the wireless issues or something. They stonewalled me and at least one other guy, but there's strength in numbers.
I too REALLY WISH I COULD FLASH THE TRENDNET FIRMWARE ONTO MY AICN77W. The trendnet camera is so much better-supported. I wish someone would hack/reverse engineer a way to do this...
geert56
Firmware with telnet for AICN747[W]
Postby geert56 » Sat Aug 29, 2009 4:50 pm
Given the GPL source and the 1.0.0-24 firmware now posted on the www.airlink101.com website, it is easy to hack up a version that enables telnet. The telnetd server executable is already present. All you need to do is activate it in the /etc/rc.d/init.d/daemon.sh script.
I posted the details and a new firmware on my yahoo group:
http://tech.groups.yahoo.com/group/mytinker/
I can report that it indeed works in my AICN747W IP camera.
It should also be possible to install other programs, e.g. dropbear. Unfortunately there is little persistent storage.
As far as I can see the device maps its root file system in a ramdisk. It doesn't use nvram.
Cheers,
Geert
knnniggett
Postby knnniggett » Fri Sep 04, 2009 12:15 pm
I just wanted to say thank you to all those that have participated in this thread.... with the info posted here I was able to get my Airlink 777W working with Zoneminder at max resolution and frame rate. Pan/Tilt controls work as well.
http://www.zoneminder.com/forums/viewto ... ht=airlink
timcraig
Postby timcraig » Fri Sep 04, 2009 5:49 pm
I installed the firmware update on Airlink's website on my 747W and Zoneminder (1.24.2) was able to access the camer's mjpeg stream when I set "Remote Host Path" to /cgi/mjpg/mjpg.cgi
I'm getting ~24-27 fps on the camera through Zoneminder now.
Airlink the gave the download an odd name of "AICN747W Original Firmware". It made me wonder if it was the firmware the camera originally shipped with. After I downloaded the zip file and open it, I saw the newer firmware version number of 1.0.0-24.
madmax00001
Airlink101 747W and 500 no workie
Postby madmax00001 » Fri Sep 11, 2009 7:22 pm
Hi All,
I've been banging my head against a wall on this one, even after reading and applying all of the great info found in this forum. I have both a 500 and a 747W that I am trying to link with ZM and still have no picture.
I am running Ubuntu v9.04 (JJ) and ZM v1.23.3. I am able to view stills on either camera using "<IPaddress>/cgi/jpg/image.cgi" using firefox on the server, but nothing through Zoneminder. I even flashed the 747 firmware to the latest version (24). Here are my settings:
Hostname = "admin:admin@192.168.0.100"
Host port = "80"
Host path = "/cgi/jpg/image.cgi"
24 bit colour
Width = 640
Height = 480
Under Options/Network I have:
Option remote = yes
netcam regexps = yes
http version = 1.1
http VA = ZoneMinder
http timeout = 2500
I am at a loss and am considering bumping Ubuntu back to 8.04, but that's a buch of work I would rather not do if possible. Any help or suggestions would be greatly appreciated.
knnniggett
Postby knnniggett » Fri Sep 11, 2009 8:57 pm
Change your host path to what is shown in the thread previously mentioned:
Your camera programs the same in mjpeg mode as the 777.
BTW: the 500 should program the same as well. I just bought a 500W and have it working great.
madmax00001
Postby madmax00001 » Fri Sep 11, 2009 10:03 pm
Knnniggett,
I tried the settings that you posted but perhaps I am suffering from newbieism and cannot find the controls for changing the settings for remote protocol or remote method. I looked through the camera settings as well as the options page. Do I need to go into terminal and try to muck with it there?
Perhaps I am missing a plugin..I thought I read somewhere that cambozola.jar is included in the zoneminder 1.23.3 package so I didn't specifically install it. I did install ffmpeg so that's not the issue.
Remote Protocol: HTTP
Remote Method: Simple
\Remote Host Name: {username}:{password}@{camera ip}
Remote Host Port: 80
Remote Host Path: /cgi/mjpg/mjpg.cgi
Remote Image colors: 24 bit
Capture Width: 640
Capture Height: 480
I also flashed the 500 firmware to the latest (B25) so the nonstandard mjpeg shouldn't be an issue.
Thank you very much for your help on this issue.
Setarcos
Postby Setarcos » Fri Sep 11, 2009 10:29 pm
timcraig wrote:I installed the firmware update on Airlink's website on my 747W and Zoneminder (1.24.2) was able to access the camer's mjpeg stream when I set "Remote Host Path" to /cgi/mjpg/mjpg.cgi
Thanks for the good news timcraig!
It's been nearly a year since I first bugged Airlink about the broken mjpeg stuff. Better late then never, I guess...
Return to “Hardware Compatibility List”
