Edimax IC-1500/IC-1500wg
rossmck
Post by rossmck »
This camera works great out of the box with ZM...
The following will give you two camera templates for the Edimax cameras;
INSERT INTO MonitorPresets (Name,Type,Device,Channel,Format,Host,Port,Path,Width,Height,Palette,MaxFPS,Controllable)
	VALUES('Edimax, 640x480','Remote',NULL,NULL,NULL,'admin:<password>@<ip>','80','/snapshot.jpg',640,480,4,10,0);
	VALUES('Edimax, 320x240','Remote',NULL,NULL,NULL,'admin:<password>@<ip>','80','/snapshot.jpg',320,240,4,10,0);
rossmck
Why not MJPEG
Post by rossmck »
Can anyone suggest why this camera wont work with MJPEG with Zoneminder - /snapshot.jpg provides a static image and /snapshot.cgi provides an MJPEG stream which works fine in my web browser but NOT with ZoneMinder;
This is what it's sending from the camera;
Server: GoAhead-Webs
Pragma: no-cache
Cache-Control: no-cache
Content-Type: multipart/x-mixed-replace; boundary="myboundary"
--myboundary
Content-Type: image/jpeg
Content-Length: 32713
<jpeg>
Which looks very similar to the output from my AXIS camera which works fine;
Connection: Close
Server: Camd
Content-Type: multipart/x-mixed-replace; boundary=--myboundary
--myboundary
<jpeg>
--myboundary
Content-Length: 32432
<jpeg>
Any ideas?
These cameras aren't bad for £40 - but it'd be nice if I could use MJPEG instead... Also *occasionally* they seem to lose their connection to the network and so the daemon stops monitoring them for a bit (reports unreachable) but this may be my wireless network so im not jumping to any conclusions)
jameswilson
Post by jameswilson »
id turn the debug up but im guessing its a non std jpg stream.
If you turn up debug and see what zm logs then. I assume you have tried reg exp on/off and http 1/1.1?
James Wilson
cordel
Re: Edimax IC-1500/IC-1500wg
Post by cordel »
rossmck wrote:This camera works great out of the box with ZM...
rossmck wrote:Can anyone suggest why this camera wont work with MJPEG with Zoneminder
So my question, is this camera compatible or not?
Do I need to move this thread out of the compatibility topic?
Thx
rossmck
Post by rossmck »
It works perfectly if you use the JPEG url above (/snapshot.jpg) ... that is just a static image but obviously ZM polls it (and it works great up to 10fps)
There's a motion jpeg feed at /snapshot.cgi - so far that *doesn't* work with ZoneMinder
rossmck
Post by rossmck »
jameswilson wrote:If you turn up debug and see what zm logs then.
Sorry for the silly newbie question, but where do I set this?
cordel
Post by cordel »
rossmck
Post by rossmck »
Thanks, it's worth mentioning that the MJPEG stream works fine with "Security Spy" on OSX ... so I'm assuming it can be made to work with ZoneMinder quite easily.
rossmck
Post by rossmck »
Debug output is as follows;
01/10/08 20:27:03.488294 zms[16212].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
01/10/08 20:27:03.488320 zms[16212].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
01/10/08 20:27:03.488517 zms[16212].ERR-zm_signal.cpp/77 [Got signal (Floating point exception), crashing]
01/10/08 20:27:03.488629 zms[16212].ERR-zm_signal.cpp/89 [Signal address is (nil), from 0x80674df
01/10/08 20:27:03.488859 zms[16212].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x80674df]]
01/10/08 20:27:03.488918 zms[16212].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x80674df]]
01/10/08 20:27:03.488956 zms[16212].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x804ae8f]]
01/10/08 20:27:03.488992 zms[16212].ERR-zm_signal.cpp/116 [Backtrace: /lib/libc.so.6(__libc_start_main+0xdc) [0x15adec]]
01/10/08 20:27:03.489042 zms[16212].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms(__gxx_personality_v0+0x211) [0x804a301]]
01/10/08 20:27:03.489080 zms[16212].INF-zm_signal.cpp/117 [Backtrace complete]
Any suggestions?
cordel
Post by cordel »
Check the FAQ for how to get info from the backtrace.
http://www.zoneminder.com/wiki/index.ph ... do_I_do.3F
rossmck
Post by rossmck »
[root@fern ~]# addr2line -e /var/www/cgi-bin/nph-zms 0x80674df 0x804ae8f
/root/ZoneMinder-1.23.0/src/zm_monitor.cpp:3125
/root/ZoneMinder-1.23.0/src/zm_monitor.h:352
efisher
Post by efisher »
Anyone find a solution for this? This is exactly what I'm seeing. I'm running on Centos 4.6 with ZM 1.23.3. It was working great with 1.22.3, but I get this everytime I try to visit the stream:
06/05/08 13:09:51.305990 zms[18784].ERR-zm_signal.cpp/77 [Got signal (Floating point exception), crashing]
06/05/08 13:09:51.306132 zms[18784].ERR-zm_signal.cpp/89 [Signal address is (nil), from 0x806b085
06/05/08 13:09:51.306529 zms[18784].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x806b085]]
06/05/08 13:09:51.306598 zms[18784].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x806b085]]
06/05/08 13:09:51.306645 zms[18784].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x804c218]]
06/05/08 13:09:51.306691 zms[18784].ERR-zm_signal.cpp/116 [Backtrace: /lib/tls/libc.so.6(__libc_start_main+0xd3) [0x626de3]]
06/05/08 13:09:51.306737 zms[18784].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms(sinh+0x5d) [0x804b711]]
06/05/08 13:09:51.306783 zms[18784].INF-zm_signal.cpp/117 [Backtrace complete]
# addr2line -e /var/www/cgi-bin/nph-zms 0x806b085 0x804c218 0x804b711
/usr/src/ZoneMinder-1.23.3/src/zm_monitor.cpp:3140
/usr/src/ZoneMinder-1.23.3/src/zms.cpp:278
??:0
MD
Post by MD »
I'm also very much interested in getting ZoneMinder to work with MJPEG stream from Edimax IC-1500. If there are any tests that might help to diagnose the problem I'm willing to try them.
cordel
Split to make post more visable and trackaable
Post by cordel »
dan86
Post by dan86 »
Hi Guys,
Apologies for digging up an old post. I have a few of these IC-1500 wired IP cams and they continually crash which requires a hard reset.
Has anyone had this issue? If so is there a fix for it?
Daniel
