I am pleased to announce that 1.22.2 has been released today.
This version is primarily a bug-fix release but also contains a small number of minor new features as well as initiali Chinese language support.
The full list of changes (from the README) is listed below :-
o FEATURE – Long events generated by Record or MoCord modes previously were not able to be reviewed until they had finished. This has changed and the event record is now updated whenever a bulk frame is generated. In most cases this will mean that the event will become replayable soon after commencing, and the record will be updated one or twice a minute.
o FEATURE – The event replay view now has some basic details about the event included as a header to the window.
o FEATURE – Weekday selection in filters is now implemented via drop down selections and not day indices.
o FEATURE – Focus is now automatically set to the username field of the login screen when the page is opened.
o FEATURE – The Fatal debug call now calls ‘abort’ to generate a back trace (if enabled).
o FEATURE – Added system status view, primarily for use by other utilities.
o FIX – Fixed an issue with an sql error concerning AlarmMaxFPS showing up when selecting monitor presets.
o FIX – Fixed the missing ‘images’ token in non-English language files.
o FIX – Added missing zone sensitivity preset.
o FIX – Fixed a problem with a missing field in the sigcontext structure on some distributions. This caused a build error when stack tracing was on.
o FIX – Fixed a problem in zmpkg.pl where one of the ‘su’ tests was missing a quote.
o FIX – Removed inclusion of Device::SerialPort perl module from zmcontrol script for IP cameras.
o FX – Added /usr/local/bin to PATH in zmupdate.pl
o FIX – Errors in shared memory access via the perl modules now invalidate the id, causing subsequent accesses to revalidate the id. Previously access would continue to invalid segments on error even if a new valid segment existed.
o FIX – All outstanding ‘assert’ calls have been replaced by more useful and informative error messages.
o FIX – Fixed a problem in some browsers where zone co-ordinates could be defined to have extents outside of the legal range for the size of image.
o FIX – Settings (e.g. paths) in zm.conf may now contain spaces.
o FIX – Fixed an issue with weekday handling in filters not being handled correctly.
o FIX – Fixed the event stills image view to correct a problem with some broken images.
o FIX – Zones were not being correctly resized when a monitor had its dimensions amended. In some circumstances this could result in a zone outside of the legal range and thereafter crashes.
o FIX – Fixed a problem with the montage and cycle views forgetting the current selected group if stills views were selected and then streams reselected.
o FIX – Corrected some typos in zmtrigger.pl to do with the showtext functions.
o FIX – Added more sanity checking in various places to ensure that zones are valid before processing.
o FIX – Increased the valid card channel range to 0-15 from 0-3.
o FIX – Corrected a problem with zmfilter.pl causing sql errors when running saved filters that used the monitor name.
o LANGUAGE – Added initial Chinese Big5 language translation.
ZoneMinder 1.22.2 Released
- zoneminder
- Site Admin
- Contact:
