Downloading ZM4MS
Downloading ZM4MS
I'm looking in the normal places, zoneminder.com, jpwilson.eu and google, and I can not find a link to download zm4ms. Is this app available?
- zoneminder
- Site Admin
- Contact:
sorry guys, ill be around a bit more now. Ill sort out a link on my site but i will be posting an updated version once i have cought up here
James Wilson
Zm4ms keeps timing out and other questions
I have it set to urls, I had it set to the ips/domains names which worked better I have no idea how to set the authenication without the urls.
With urls, zm4ms with timeout and not restart, is there a way to set zm4ms to
1) set Autocycle the current view as a default on startup?
2) where to put the password without putting in the url?
3) set zm4ms to skip the currrent view if it timesout and retry next time?
you need to avoid url's as that was for a differnt project.
I would think you have a path issue and we need to resolove that.
Auth wise it uses the same use as you log into zm4ms with so if you must ensure your zm4ms user details match your zm box
Once we have that working ill try to understand your other questions
James Wilson
