need to keep an eye on a remote location?
R3MF
Post by R3MF »
got a sempron64 @ 1.6GHz + 256k cache
512MB DDR400
Via K8M800 motherboard
80GB HD
i reckon we need about two IP cameras and two USB cameras to cover the while building, any recommendations on extra hardware needed to complete the build?
Axis 206 for £133.49 -
http://www.dabs.com/productview.aspx?Qu ... 0000,50751
Gadspot GS1000 for £104.49 -
http://www.gadspot.co.uk/proddetail.php?prod=GS1000
which would be better?
any suggestions on USB cameras, preferably available from dabs?
cheers
jameswilson
Post by jameswilson »
definetly use the axis's and i also wouldnt use webcams if you have the budget
James Wilson
R3MF
Post by R3MF »
ok, cheers.
Flash_
Post by Flash_ »
Yep, 206 is a great internal IP camera.
FYI. shopaxis.co.uk had a "3 for 2" offer on 206's last week, not bad as they're usually the cheapest supplier anyway. (Also reliable - I've had 10 cameras from them over the past year)
zoneminder
Site Admin
Post by zoneminder »
Most of the 3 for 2 type offers are direct promotions from Axis. So if you see one somewhere then chances are they are available everywhere and it's always worth asking!
Phil
R3MF
Post by R3MF »
cheers both.
just out of curiosity, has anyone tried these:
http://www.scan.co.uk/Products/ProductI ... tID=158949
Sweex IP Network Camera JA200010
they are half the price, so while i appreciate you get what you pay for, if someone knows they work ok I might opt for these.
regards
