Installation
B F
Installation
Post by B F »
Bit out of touch with Zoneminder and having trouble getting started with a fresh install.
Trashed my CentOS version this morning and installed Ubuntu + Connor's PPA https://launchpad.net/~iconnor (thank you for this). All went well but where do I go from here?
Might be there's some missing info at https://cloud.zoneminder.com/downloads.html as it says "Results will appear here" or "window.location='/error/error_login.html';" depending which option is chosen.
Seem to recall there's a config script that has to be run first... it's been a while.
Started Zoneminder with
# service zoneminder start
and it runs fine but when I go the URL
https://192.168.200.100/zm/
There's "Problem loading page" message meaning there's nothing there.
Thanks in advance.
Re: Installation
Download page results has been fixed.
Here is my youtube channel. Any of the install videos on any version should help as the steps are the same regardless.
https://www.youtube.com/channel/UCDKfmv ... 6rO2aj5Wlg
