My very Chinese Dahua "IPC-EBW81200" 360° uses the unusual resolution of 4000x3000.
Is there any way to set the capture resolution to that or disable the warning in the logs (it annoys me).
Custom resolution of 4000x3000
Re: Custom resolution of 4000x3000
Under Source/Capture Resolution you should be able to manually enter your "custom" resolution.
Well, it is good to do no harm and leave nothing behind except footprints. There was a time, it seems like long ago, when you had to manually enter the resolution. Then the developers started to bring the product into the modern age! I'm not as active in the forum as I once was but still work on the WIKI install procedures.
