I have ZM 1.36 installed yesterday and I would like to inegrate a esp32-CAM.
The cam is working fione. I am getting a video stream via web browser.
http://192.168.178.114:81/stream
(I was able to setup a different cxal via rstp stream )
However, I failed for the esp32-cam.
Is this cam supported?
Is there a documentation/tutorial?
Thanks in advance!
Matthias
camera setup - esp3-cam
Re: camera setup - esp3-cam
Try it with VLC. If that works, ZM will. Only diff is TCP (usually) or UDP, some cameras.
I seem to recall there was some issue with the jpeg stream that zm didn't like.
viewtopic.php?p=128536&hilit=esp#p128536
