A memory leak located?
pygr
Post by pygr »
Version 1.37.45
Before another memory allocation is made for
packet->image
, is the old one deallocated in the method Monitor::Decode() in zm_monitor.cpp?
If I put
delete packet->image;packet->image = nullptr;
near the end of Decode(), zoneminder seems to leak memory less badly. I haven't noticed any bad side effects.
I'm seeing other memory leaks, but I want to get a better handle on them before I post anything more here.
Re: A memory leak located?
I’d suggest using Slack as that’s where the Developers hang out.
I'm here. I'll take a look.
If you delete the image, then we can't do analysis on it later....
The image is deleted when the packet is deleted.
pygr
Post by pygr »
Does turning analysis off cause a memory leak? In my setup I turn off analysis because, instead, I have the ONVIF event listener triggering events.
I'm now thinking perhaps it's better to put the "delete" command just before the "new" command for "packet->image" towards the beginning of Monitor::Decode(). That way, if I ever decide to turn on analysis, things should work properly.
pygr
Post by pygr »
Further investigation disproves the notion that packet->image is involved with a memory leak.
Sorry, my bad.
pygr
Post by pygr »
Magic919 wrote: Sun Oct 08, 2023 7:43 am I’d suggest using Slack as that’s where the Developers hang out.
Good suggestion! Thanks.
